Old 03-25-2012, 01:56 PM
Stepside's Avatar
Stepside Stepside is offline
Super Moderator
Stepside will become famous soon enough
Default Re: Aeromax Daycab Dump 6x6 (Update: 3/18)
Some more progress! Got the body mounted. I knew after I had the trans mounted that I was about 1/8" to 3/16" out of the rear of the cab, so I had to build a small dog box to get everything enclosed. Also used the factory cab mount to add some real estate inside for mounting electronics.
I ordered a full set of topcad off road tires, once they come in & I get them mounted, I am going to check out the front axle & suspension to see if I need more clearance for the offroad tires...
"If you build it, they will come"
East Coast Mini Truckers
