Old 02-01-2014, 10:14 PM
DADSGARAGE's Avatar
Default Re: 777 HAUL TRUCK (1/12 size)
Made the box pivot pins.....again still needs to be soldered together....
Old 02-01-2014, 10:51 PM
DADSGARAGE's Avatar
More welding and sanding....
-Cab
-Top deck
-Grill box
Mounted the side deck beside the cab and the hand railing....still need to solder one ladder together....
Thanks for looking!!!
Hopefully some of the pics of this simple model will give you some ideas for your next build...hopefully!!
KP
Old 02-03-2014, 02:45 AM
KP
Seeing what you're creating from the use of a waterjet table vs the usual cnc works is quite amazing! What's the ballpark $figure for such a tool?
Old 02-03-2014, 06:02 AM
Joe , starting in the $40K range
Great work
Old 02-03-2014, 11:10 AM
JAMMER JAMMER is offline
You have a lot of nice ideas when it comes to making parts and details. You are moving along nicely soon you will be hauling dirt keep up the good work. Ed
Old 02-05-2014, 08:46 AM
Dads , how well does that H2O jet cut gear teeth ?
777 looks great so far
Old 02-06-2014, 10:19 PM
DADSGARAGE's Avatar
An "OMAX" 55100 waterjet table retails for about 200K US$
The waterjet does a great job cutting "straight" gear teeth profiles , all the gears I have cut have been used "as is" after cutting on the table short of doing some filing, but if you needed a high precision gear it would be best to cut the gear blank slightly bigger and then use the proper gear cutter to finish it...
Thanks !!
