#81
sorry claus - gonna have to wait a little while longer - went to take a photo of her all dressed up and the camera battery died...... maybe she's tired of having her picture taken?????
#82
That ain't right.
#83
I do have the same axles , just loosen up the diff covers , then pay close attention to which screw of the diff-covers is right in the center of the axle , loosen that screw , use a short one or add a washer .
(Wild)-Willy CustomRCmodels |
#84
I reversed the locking action of these axles . By default they are not locked , the small external spring on that lever has to overcome a coil-spring on the inside . Means NON-locked , this inside spring is always compressed . If you remove that spring on the outside lever the axle will be always locked and only unlocked if you pull the lever . I like it that a way much better , the inner spring is not compressed all the time , and it takes a lot less torque now to push/pull that lever for un-locking the axles . I just gone use a micro-servo above the axles , inside the frame and connect the servo-arm with a small tension-spring to the diff-lever , ( spring = to make up for suspension-travel ) to unlock the axle
#85
Hey Izzy where did you get that cylinder for your brake setup if i may ask?
#86
Nathan |
#87
Seedy8305 - look up firgelli on the web - it's operating the lockers on the duffs
#88
Hello everyone
![]() ![]() ![]() ![]() ![]() ![]() Soooooo Metal shift plates and a new case for the trans - had been way to hacked up to put back in ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
#89
#90
Well if you blow a trans now you are really trying to do too much with it!! Looks great!
#91
Nice upgrades! Been wondering about those gear sets for the transmissions and what people thought of them. I can't believe you actually wrecked a gear in the stock transmission. Did you always run a brushless out-runner? That's probably why. I see a planetary reducer on the input too. That has to be powerhouse.
Nathan |
#92
Gorgeous Nice decal and paint work, sharp lines!
#93
Hey Izzy! Truck looks good!
How is that rear suspension still holding up and performing? Any issues with the plastic springs? |
#94
Is that a custom mount for the outrunner motor?
#95
wonderful good. Giuseppe
#96
Looks great Izzy keep up the good work.
There are no decals on the truck it is all paint and the guy who did the paint work is a sick individual, no air brush he did it all with a full size automotive paint gun. He is not cheap but you can't beat the quality. Here are two build threads on trucks he painted as well http://rctruckandconstruction.com/showthread.php?t=349 http://rctruckandconstruction.com/showthread.php?t=984 Travis
#97
Truck looks great with the added details cant wait to see it next week.
#98
That gear reduction came factory made - had to turn fown the output shaft to fit the helical pinion though.
I like the helical gears - nice bling - joe and others have shown that a stock transmission is plenty strong and durable. No need to do what I have done - even with an out runner. It all domes down to how you drive. |
#99
looks great keep up the good work
#100
How is the truck running these days Chris? It's a beautiful rig. Curious who made your gorgeous grille?
