Old 09-08-2014, 07:15 AM
Rvjimd's Avatar
Rvjimd Rvjimd is offline
Default Re: What motor/esc?
John,
I don't know what scale you are going with but the helicopter main gear that I used on my crane might be in the ballpark for you mixer. And, I know you can get different sizes for the different model copters, and they are not that expensive.
This one fits a T Rex 500.
If you have a space under the frame or in the cab I would try and use a servo converted to continuous rotation and then make a fles shaft to run up to the gear and put a pinion on the end of the shaft.
Jim
Old 09-08-2014, 08:41 PM
Originally Posted by Rvjimd View Post
John,
Jim
Hey thanks a lot Jim. I was thinking of the servo idea, and it would take less room as far as another esc and motor. BTW, it will be 1/14 scale. I am curious where you got the gear, I would like to take a look at their web site.
Thank you, Big John
Old 09-08-2014, 09:00 PM
Rvjimd's Avatar
John,
I grabbed a two pack off the rack at my local hobby shop. Here is a pic of the header from the pack.
Here is a link to heli direct.
http://www.helidirect.com/advanced_s...e+gear&x=0&y=0
You will probably find hundreds of different ones here...
Jim
Old 09-08-2014, 09:32 PM
John,
Jim
Thank you Jim.
