![]() ![]() ![]() got a bit of painting done, want to paint all the light holders and still waiting for front guards to turn up, also have a slight problem with the loader. one of the rear wheels has come loose and my small nut driver has gone missing so I cant sort out my loose wheel. I don't want to go to the local hobby shop just yet, It could end up costing a lot.( usually dose , all those shiney things) cheers for now. going to redo the decals on the arm as not correct and also theres a few to go on the motor housing . ps the loader is only allowed inside if it sits on the newspaper LOL. Last edited by andyathome; 09-08-2014 at 05:37 PM. Reason: ad a few extra words |
I can't help but drool when I see this beauty.
![]() ![]() ![]() ![]() Mario |
Hey Andy ,you sure have a awesome fleet ,keep up the great work !!
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
all right time for some updates.
excavator: ordered a sound card from eagle machinery ( same as my loader) and crammed it into the excavator, am running it of the 4th valve so after my Y cable (signal reversing) turns up it should be all go. ![]() have also made a few decals for the rock truck, ![]() also had a slight problem with the loader. had a rear wheel come loose from the axial, emailed tang at eagle machinery and got a detailed how to do , remove wheel, remove ring gear, pull axial, pull washer , look inside and find 4 small bolts holding planetary gear to axial housing tighten up and all good. ![]() ![]() new drive motors for excavator have turned up so will fit those when I have a bit of time, also front fenders for loader here and painted. ![]() also have eight more diggers, early one morning on my way to the shed for a bit of play time and I spot this. ![]() |
http://youtu.be/VR1NbwjUCOU
heres a real quick video of the sound card, flat battery. you can see how the revs drop when the sticks are moved, the signal reversing lead will fix this. cheers andy ![]() |
I like this shot Andy
just the right distance and angle to make the Shed look the same scale nice |
cheers paul,
waiting for better weather then a few more outside shots. got the conveyors finished and running good. need to put loader back together, had a bearing failure in the rear diff. input shaft bearing toast! got a new gear set from manufacture (free) and put some shims in around main diff gear bearing, and milled a bit of clearance for the diff lock leaver ,also rechecked front diff and fitted shims, milled a bit out the same as rear diff. need to find a bit of time for a play to see if it is all good. cheers andy ![]() ![]() |
