all right time for some updates.
excavator: ordered a sound card from eagle machinery ( same as my loader) and crammed it into the excavator, am running it of the 4th valve so after my Y cable (signal reversing) turns up it should be all go. ![]() have also made a few decals for the rock truck, ![]() also had a slight problem with the loader. had a rear wheel come loose from the axial, emailed tang at eagle machinery and got a detailed how to do , remove wheel, remove ring gear, pull axial, pull washer , look inside and find 4 small bolts holding planetary gear to axial housing tighten up and all good. ![]() ![]() new drive motors for excavator have turned up so will fit those when I have a bit of time, also front fenders for loader here and painted. ![]() also have eight more diggers, early one morning on my way to the shed for a bit of play time and I spot this. ![]() |
http://youtu.be/VR1NbwjUCOU
heres a real quick video of the sound card, flat battery. you can see how the revs drop when the sticks are moved, the signal reversing lead will fix this. cheers andy ![]() |
heres a better video showing the issues I have .
sound card wont shut down, because Im using the 4th bypass when there is no stick movement the revs are high. in order to shut down the sound card I have to stop pump, use a stick , drop sound card revs then use a track and all shuts down. when the reversing lead shows up all these steps will be gone, hopefully ![]() https://www.youtube.com/watch?v=Hprhm-bqzXs |
Andy you got that machine looking amazing and she seems to be running nicely keep up the good work
I like this shot Andy
just the right distance and angle to make the Shed look the same scale nice |
cheers paul,
waiting for better weather then a few more outside shots. got the conveyors finished and running good. need to put loader back together, had a bearing failure in the rear diff. input shaft bearing toast! got a new gear set from manufacture (free) and put some shims in around main diff gear bearing, and milled a bit of clearance for the diff lock leaver ,also rechecked front diff and fitted shims, milled a bit out the same as rear diff. need to find a bit of time for a play to see if it is all good. cheers andy ![]() ![]() |
Currently Active Users Viewing This Thread: 7 (0 members and 7 guests) | |
