Old 09-09-2014, 07:31 AM
pumptech's Avatar
pumptech pumptech is offline
pumptech is on a distinguished road
Default Re: JBC limited NZ
Hey Andy ,you sure have a awesome fleet ,keep up the great work !!
Old 09-09-2014, 09:35 PM
just one more in the sunshine.
Old 09-18-2014, 04:07 PM
all right time for some updates.
excavator:
ordered a sound card from eagle machinery ( same as my loader)
and crammed it into the excavator, am running it of the 4th valve so after my Y cable (signal reversing) turns up it should be all go.
have also made a few decals for the rock truck,
also had a slight problem with the loader.
had a rear wheel come loose from the axial, emailed tang at eagle machinery and got a detailed how to do , remove wheel, remove ring gear, pull axial, pull washer , look inside and find 4 small bolts holding planetary gear to axial housing tighten up and all good.
new drive motors for excavator have turned up so will fit those when I have a bit of time, also front fenders for loader here and painted.
also have eight more diggers, early one morning on my way to the shed for a bit of play time and I spot this.
Old 09-18-2014, 05:07 PM
http://youtu.be/VR1NbwjUCOU
heres a real quick video of the sound card, flat battery.
you can see how the revs drop when the sticks are moved, the signal reversing lead will fix this.
cheers andy
Old 09-19-2014, 01:49 AM
heres a better video showing the issues I have .
sound card wont shut down, because Im using the 4th bypass when there is no stick movement the revs are high.
in order to shut down the sound card I have to stop pump, use a stick , drop sound card revs then use a track and all shuts down.
when the reversing lead shows up all these steps will be gone, hopefully
https://www.youtube.com/watch?v=Hprhm-bqzXs
Old 09-19-2014, 03:39 PM
headers headers is offline
Andy you got that machine looking amazing and she seems to be running nicely keep up the good work
Old 10-03-2014, 07:59 PM
PaulNZ's Avatar
PaulNZ PaulNZ is offline
I like this shot Andy
just the right distance and angle to make the Shed look the same scale
nice
Old 10-03-2014, 09:44 PM
cheers paul,
waiting for better weather then a few more outside shots.
got the conveyors finished and running good.
need to put loader back together, had a bearing failure in the rear diff.
input shaft bearing toast!
got a new gear set from manufacture (free) and put some shims in around main diff gear bearing, and milled a bit of clearance for the diff lock leaver ,also rechecked front diff and fitted shims, milled a bit out the same as rear diff.
need to find a bit of time for a play to see if it is all good.
cheers andy
Old 10-04-2014, 12:26 AM
took the trailer for a drive.
Currently Active Users Viewing This Thread: 8 (0 members and 8 guests)
