Old 08-16-2010, 09:29 PM
Default Re: Driven front axle options?
I use the TLT-1 tamiya axle you can get a new axle kit from tower hobbies but it would be cheaper to try evilbay. As for the shaft they are on e bay as well but you could just buy an Axial trans to use as a transfer case I have used two of them and they work great and they are about $35-40. Here are my trucks with the TLT-1 in them. You can also use a highlift axle they have the same gear ratio as well but they are wider than the TLT-1
I hope this helps.
