Old 08-19-2010, 07:29 PM
FreddyGearDrive's Avatar
FreddyGearDrive FreddyGearDrive is offline
Admin RIP FGD 2-12-59/12-19-11
FreddyGearDrive is a jewel in the roughFreddyGearDrive is a jewel in the roughFreddyGearDrive is a jewel in the roughFreddyGearDrive is a jewel in the rough
Default Re: Driven front axle options?
SmallHaul, This is the diff between stock & rc channels narrowed.
Now carson & rc channel.
With these two you can run super singles w/out dickin around.
Now TLT.
F-350.
This will give you the low down in a row.
Hope this helps.
FGD
Old 08-19-2010, 09:43 PM
SmallHaul's Avatar
Great info Freddy! You should make this a sticky.
So, starting from narrowest to widest:
1) Stock front axle
2) Carson
3) Rcchannel narrow
4) TLT-1
5) F-350
Does that look right?
If so, where would I get a Carson axle? and how much?
Scott
"No load is too Small"
Old 08-19-2010, 10:31 PM
BINGO!That's the exact order.
SmallHaul,the carson front diff is like $200.
For the same price you can get this.
But! Now you have to buy a set of semi rear diffs to match the front. The rear diff that comes w/the front is two wide for semi. But you can't beat the look of these babies.
The carson is like 2mm narrower than rc/channel.
The carson I was purchasing from pmd. But surf a little & you can pick them up a lot cheaper.
Hope this helps!
FGD
Old 01-02-2011, 03:24 PM
Snochaser's Avatar
Hope this helps!
FGD
So are these Carson axles?
Old 01-02-2011, 07:21 PM
Snochaser,The aluminium one are R/C Channels.The plastic one is the carson.
Old 01-02-2011, 01:10 PM
CustomRCmodels's Avatar
CustomRCmodels CustomRCmodels is offline
CustomRCmodels is on a distinguished road
Now TLT.
F-350.
Hope this helps.
FGD
since I just came across this thread again and it’s a sticky one ,
I figured I add this here :
Example of the use of a TLT-1 axle in one of my 6WD projects:
http://customrcmodels.com/Trucks/new_6wd_project.htm
(Wild)-Willy
CustomRCmodels
