Old 06-27-2020, 09:19 AM
Bo Wallen's Avatar
Talking Re: KH Beam Hauler
The plan is,
[IMG]IMG_6253 by Bo Wallen, on Flickr[/IMG]
Old 06-28-2020, 01:00 PM
NRS91 NRS91 is offline
NRS91 is on a distinguished road
Default Re: KH Beam Hauler
Originally Posted by Bo Wallen View Post
The plan is
ooo very nice! whole new fleet eh?
If you are looking for cheap tamiya based driven steer axle conversion kits then watch my store
Thanks
Nick
Old 07-01-2020, 09:24 AM
Bo Wallen's Avatar
Exclamation Re: KH Beam Hauler
Thanks, Nick. Yes, a slight extension to the fleet, Your front axles will be needed for two of the Benz. The Lesus is just garbage
Old 07-01-2020, 09:51 AM
I guess you dont have issues with the stock Tamiya rear axles?
Here is a sneak preview for you
Thanks
Nick
Old 07-01-2020, 08:33 PM
Bo Wallen's Avatar
Thumbs up Re: KH Beam Hauler
Thank You, Nick. I have a good feeling about your project. I will Have your product Incorporated in my fleet. The original Tamiya axles are right, and if they get tuned tight when built, they will last a long time. I have axles with far more than three hundred hours on them, still running smooth. So let's have the two current Mercedes on the bench run your front axles.
I am looking forward to working with you. Nick.
Old 07-01-2020, 08:45 PM
I currently have 1 pinion out of 6 which jumps out of mesh, it's a different design to the other 5 on the 8x8 so not sure where it's from but will add a circlip or washer between the gear and bearing then full testing can commence!
Thanks
Nick
Old 07-02-2020, 12:03 AM
Bo Wallen's Avatar
The Mesh is extremely important on casted gears; There is no shortcut at that.
However, Tamiya does not make metal parts in the house. Therefore the gearbox has two different pressure angles on the gears, Old standard and new. Witch makes the gear to go down faster than it would with the same pressure angles. Now Japan is a monoculture, so the boss does not know that, and a new gearbox or axles will not be on the horizon for some time. But the work so I stick with them.
Currently Active Users Viewing This Thread: 27 (0 members and 27 guests)
