Old 09-27-2020, 01:31 AM
Hollywood2979 Hollywood2979 is offline
Hollywood2979 is on a distinguished road
Default Re: CAT 14M3 Motor Grader
What would something like this cost to have built?
Old 08-31-2021, 05:09 PM
denn1s33's Avatar
denn1s33 denn1s33 is offline
denn1s33 is on a distinguished road
It's been a long time. I was wondering if there are any updates on project, did you complete it? I watch your latest video almost every day. I wonder if you still have a chance to upload a new video?
Thank you.
Old 09-11-2021, 02:25 AM
Thank you.
It's basically ready, but I've been struggling to get everything work with my old radio. I just received a new 18 ch Flysky radio that should have enough channels
Old 10-10-2021, 12:12 AM
I have one unused hydraulic valve on the grader, so I decided to start making a ripper to the rear
Old 10-10-2021, 10:30 AM
Time to bring out the popcorn again
Old 10-10-2021, 03:02 PM
how's that paladin radio working out? i wanted to get one but ended up adding 4d sticks to my taranis 9e
Old 10-16-2021, 10:37 AM
No complains on the radio, easy to set up and feels sturdy. I really like those side levers, that I use to lift left and right side of the blade on the grader.
Old 10-31-2021, 05:45 PM
Filipe Erme Filipe Erme is offline
Filipe Erme is on a distinguished road
Qual a dimensão dos pneus
Old 11-07-2021, 12:26 AM
The wheel diameter is 120mm and the width is 46mm.
Old 11-07-2021, 06:42 AM
More parts for the ripper
Old 11-13-2021, 12:54 PM
Sounds like you've had some stick time on the grader, where's the videos?!
Old 11-14-2021, 07:06 AM
I still have some electronic updates to do. Also while setting up the radio, I found a leak on the blade side shift cylinder hose. I most likely have to change the hole hose, and of course, that's the most hardest one change.
Old 11-14-2021, 12:38 PM
BlackCat BlackCat is offline
BlackCat is on a distinguished road
Are you using sheet metal option in Fusion 360 to design these parts?
Old 11-14-2021, 12:44 PM
Yes I am.
Old 11-14-2021, 12:46 PM
I welded some parts together for the ripper.
Old 11-14-2021, 07:42 PM
Tgrzes Tgrzes is offline
Tgrzes is on a distinguished road
Those parts are looking awesome! Very nice!
Old 11-14-2021, 09:30 PM
This project is nuts, it just keeps getting more awesome!
Plus that's some pretty sweet looking low profile Tig work.
I've got to second Lil Giants question. Videos?
Old 11-21-2021, 10:21 AM
Few more parts partly done
Old 11-28-2021, 09:51 AM
I got the ripper teeth holders done and welded. I also started to make the teeth bodies, the tooth tip is a separate piece.
Old 11-28-2021, 06:18 PM
Beautiful work as always. Are you using a filler wire on your welds or just doing a series of spot welds?
