Old 11-14-2021, 07:06 AM
Default Re: CAT 14M3 Motor Grader
Sounds like you've had some stick time on the grader, where's the videos?!
I still have some electronic updates to do. Also while setting up the radio, I found a leak on the blade side shift cylinder hose. I most likely have to change the hole hose, and of course, that's the most hardest one change.
