Old 08-24-2010, 11:03 PM
Bob From Downunder Bob From Downunder is offline
Bob From Downunder is on a distinguished road
Default Re: Cool tranny mod for front wheel drive (Vid added)
Hi Scott this is fantastic, well thought out and has a lot of protential for 6x6 users. Can you please tell me where you bought the gears from. This is what I have been searching for. All I need to do now is find a way to disconnect the front drive.
Bob
Old 08-25-2010, 09:32 AM
SmallHaul's Avatar
Bob
You can find all of the gears on ebay. I used 32 pitch.
I used two 18 tooth pinion gears (5mm bore)
http://cgi.ebay.com/Traxxas-Tra5644-...efaultDomain_0
and one 22 tooth pinion gear
http://cgi.ebay.com/Traxxas-E-Maxx-2...ts_Accessories
The size of the center gear will not change the ratio as long as the 2 outside gears are the same. So, you could run a 28t 32p gear for the idler gear and that would lower the final output shaft a little.
28t 32pitch 5mm bore gear:
http://cgi.ebay.com/CASTLE-CREATIONS...ts_Accessories
Scott
"No load is too Small"
Old 08-25-2010, 10:44 AM
ihbuilder's Avatar
Scott , Your right till you get to "would lower the final output shaft a little." It dose not matter what size Idler gear as long as the input and output are the same you would not change the ratio . Now If you are referring to changing the out put to a 28 tooth then yes you would lower the ratio. All Idler gears do is keep the output same rotation as the input . But very good Idea as the same for willy ( custom rc models ).
IHSteve
Old 08-25-2010, 11:03 AM
SmallHaul's Avatar
Steve, When I said "would lower the final output shaft a little." I meant lower the height of the output shaft not the ratio.
Scott
Old 08-25-2010, 09:56 PM
ihbuilder's Avatar
Sorry my bad no offense
IHSteve
Old 08-25-2010, 11:03 PM
SmallHaul's Avatar
You are welcome Bob but, I wouldn't recommend doing this conversion unless you have the time and tools because an axial trans or an f-350 trans would be a lot easier.
It probably took me 6 or 7 hours to make this but, every time a drive it I will be rewarded that I made it myself. It should sound really cool when it is done because there 8 gears driving against each other from the motor shaft to the final output shaft and there are 2 sets of those gears in metal cases, the hpi GRU and the GRU I made.
No offense taken Steve!
Scott
