Old 07-04-2011, 12:02 AM
Default Re: Rollback tow truck
Originally Posted by firefighter30 View Post
Travis, the truck and center caps look really nice, good work.
Thanks Doug I am glad you like them.
Originally Posted by skl1cent View Post
i really like the center caps on your back wheels where'd u get those?
They are real simple and easy to do. The caps are just snap caps epoxied to axial hub nuts used on the ax10. Link to axial caps To do this you need to replace the thick lock nut that holds the wheels on with a regular thin 5mm nut using some loctite. By doing that you will expose more axle shaft threads for the axial hub nut to screw on to. The axial hub nut would probably be enough to lock the other nut from coming off but I put loctite on just to be safe.
Here are some pics of today's progress. New chassis done, cab painted, and a good start on the bed lift and slide mechanism.
Thanks for looking.
Travis
