Old 08-08-2011, 09:25 AM
td9clyde td9clyde is offline
Dozer Builder
Default Re: Mack M75SX
Nice work on the cab looks good can't wait to see this one haulin
Old 08-08-2011, 10:49 AM
me too Henry gota get it ready for winter for loading the coal hopper
well my butt is draggin today finished up about 4 AM 8 hrs of cutting but then I kept my feed down I hate breaking EM's mid way through I tried to flip it over and do the inside this morning but the stock is a lil out of square + being tired I was running the wrong program oh well enough B.S. pics
back to work
Old 08-08-2011, 11:27 AM
steamer's Avatar
steamer steamer is offline
Steve. You knocked that one, right out of the park, and there must have been quite a pile of chips on the floor. The frame on this truck looks like it will be rock solid and heavy duty.
Rob
Old 08-08-2011, 10:54 PM
thanks Rob I got the back milled out just off the mill 30 min ago ( I'm gona get some sleep ) everything went well till the drill cycle for some azz reason my holes are out .125" I should have waited and bored the 2 together manually
the "I" profile
looks like the verizon strike is effecting my I-net
Old 08-08-2011, 11:00 PM
sneaky-pete's Avatar
Master A-Modeler
Nice work Steve....your skills amaze me.
Troy
Old 08-08-2011, 11:10 PM
Hmm, Did you forget to take .100'' off from the edgefinder?
Any pictures of your set up on the machine?
Old 08-08-2011, 11:22 PM
yes I remembered that other wise the backside pocketing would be off . It may be that when using the cam I clicked on the circle edge and not center I'm not sure you can see it in this vid http://www.youtube.com/watch?v=XLyOWczx1DQ
if not I'll take a pic when I do the other side or a trailer frame I'm going to set up . It's basically a fence that I can bolt the stock to .This trailer frame set might take a few days + igot to get more plate for the othe side
Old 08-09-2011, 07:56 AM
For drilling, I draw points to generate the code .
Old 08-09-2011, 07:57 AM
tc1cat's Avatar
tc1cat tc1cat is offline
Super Moderator
Looking good!! And everyone thinks that running a CNC mill or lathe is just push the go button and everything comes out OK Slowing down the feedrate is not that bad of a thing to do. Recommended feeds and speeds are not all what they are cracked up to be!!!
LYNN
