Well that's where I am at this point in time.
I am patiently waiting for Steve (ihbuilder) to make my Air Cleaners, Fuel Tanks, and Wheels. Then I have to get the motor to Lynn for some machine work needed to put the steering servo inside the motor. Then get the MFU and the electronics installed along with the drive motor and transmission. Once I get all that done and everything works right then I will paint her up and start the final assembly.. Now all that is looking like it won't happen for quite a while. ~Mike~ |
Wow this is one beautiful rig all the detail just wow i am awestruck so i gotta ask when you do the lights will the dashboard have lighted gauges and such?
Mike
Yes they will be back lit. The turn signal indicators and the high beam indicator will also work. ~Mike~ |
Again excellent work ![]() Mike
I was thinking of making my own decals of the gauge faces on clear decal paper. Since printers do not print white that means the white numbers on the gauge face will be left clear for the light to come through. Then I will adhere them to a piece of clear overhead projector sheet and cut to size. Next I will drill the holes in the dash in the appropriate spots and make them just a hair smaller diameter than the gauges I have just made. Then glue the gauges to the dash. Next I will build a small box for behind the dash and light it with some 2x3 mm LED's. the inside of the box will be covered in aluminum foil to give it a reflective surface. The LED's will be mounted on the underside of the dash facing the box with the aluminum foil thus causing the light going through the gauges to be both uniform and slightly defused so as not to be so overwhelming. As for the turn and high beam lights I will use the appropriate colored LED's sent threw fiber optics. ~Mike~ |
Good to have you back among us, I missed classy shak
Nick My Peterbilt build thread: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
http://www.ecofoil.com/All-Products/...e-Tape-2-x-150 I know you can get this in any hardware store it is a metal tape with a paper backing to peel off and it's already glued, used to do AC work with my dad and we used this type of tape alot,and this tape will polish up pretty good, just a thought. Mike
simply amazing build..
Michael also known as "The Crimson Corsair" To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
