Go Back   RC Truck and Construction > R/C Truck's Manufacturers/Venders/Retailers > S n P Customs
S n P Customs Custom builds, Custom parts, Custom metal polishing...
Old 02-05-2012, 12:06 AM
1985 kenworth's Avatar
Question Re: Custom fenders
how would you make them to order by which tamiya or wedico tractor you have and which suspension you are using on the tractor
Old 02-05-2012, 12:11 AM
Default Re: Custom fenders
They would be made for a Tamiya truck with a standard suspension or a custom suspension as long as the ((wheel base) typo should be wheel spacing of the rear axles) stays the same. The fenders are made to fit a standard Tamiya truck.
Old 02-05-2012, 10:40 PM
ok i have a kinghauler and a globeliner the suspension is stock but the wheelbases on them are longer than the standard box stock trucks are you sure the wheelbase would be an issue i thought the axle spread would be the a problem ..i am talking about someone building the mounts to mount them on the trucks
Old 02-06-2012, 02:01 AM
Dreamweaver's Avatar
Weaver Of Dreams
Wheel base would not be an issue unless you changed the drive wheel spacing, which you can't do if using a stock suspension. However if you were to use the air ride kit that Russ sells then you could change that spread. However if you were to change the drive spread then the fenders would not fit anyway.
Mike "DREAMWEAVER" Johnson
Old 02-06-2012, 01:57 AM
Weaver Of Dreams
I build them so that they fit the way you want them regardless of the make of truck or type of suspension. I get measurements from you, I let you determine how high you want them to sit from the wheels and the ground then build them to fit.
I guess I could make a "Stock" set. If you have a stock Tamiya suspension, stock ride height ect and you want the full length fender as they come from John then no measurements are needed. I could also build a set that has a little extra adjustment to them and someone with basic soldering skills can make them the height they want and just trim the excess.
