thats all well and good , but what happens when you get oil in the magnets . I've tried this with 2 of the smaller 1's I got as complete units .
the one that was on ebay was a mag drive pump it does not matter if you get oil on the magnets as they don't touch anything in fact there is plastic between the two magnets or are you talking about the one that was converted to shaft drive? |
the reason for the mag coupling is to eliminate shaft seals I have 2 complete pump and motor set up with a mag drive . I tried 1 , as soon as I got oil in it it lost conection . They are not designed to pump oil with out removing the mag drive . then lies the ? if the poly pump gears will hold up in oil
SHANE... Member of the Central Plains Mini Truckers.. |
it is nice to be able to ask questions and have a adult conversation with someone without be called out or being made fun of because of an miss-understood question or reply unlike at scale4x4 where folks jump down anyone's throat that asks a question that may or may not have been answered in the last ten years. it seems that i need to ask the company why they say the pump will pump oil or heavy fluids, as you have tried and failed again thanks for your time and trouble answering my questions grumpygrady |
