Old 10-27-2012, 07:03 AM
Default Re: CAT 374D L
I was able to do some test runs with the undercarriage
http://youtu.be/bjVBu86-agE
Old 10-27-2012, 07:27 AM
Snochaser's Avatar
Absolutely awesome. Great job. Can't wait to get mine.
, you will not be forgotten.
R.I.P. FGD
Work Hard, Play Hard!
Never Forget- 343
Old 10-27-2012, 10:52 AM
rockNmayhem's Avatar
Wow that looks amazing. The tracks seem very smooth and track great. I can't wait to see the rest of the machine come together.
Tyler
~Tyler~
RockSolidCustoms
Old 10-28-2012, 09:54 AM
ihbuilder's Avatar
great job , Ari If your around 64.25 mm you should be good for the wide shoes .
Old 10-28-2012, 11:00 AM
I did some work with the stick today
Old 10-28-2012, 01:41 PM
speedy8305 speedy8305 is offline
speedy8305 is on a distinguished road
I must say that is looking awesome cant wait to see the finished product will be something to see
Old 10-28-2012, 05:11 PM
Jw.'s Avatar
Jw. Jw. is offline
Jw. is on a distinguished road
Awesome work on the stick and your undercarriage! Speaking of track pads. How long are your track pads?
64.25mm sounds good. That's after the 900mm(35inch) track pads scaled down? That's what I'm doing and added just a little more. The track pads I made are 66.00mm wide and 19.70mm long. After the 900mm pads for my 390.
Do you know the actual size of a 900mm width track pad for a 374? Length wise? Is it the same between 374 and 390?
Thanks
Jeff
Old 10-28-2012, 06:33 PM
plow jockey's Avatar
plow jockey plow jockey is offline
plow jockey is on a distinguished road
Outstanding job!!
One is too many and a million is not enough. Fred.
Old 10-29-2012, 12:27 PM
Thanks
Jeff
I made mine wider, they are actually 80mm wide. I don't like the look of an large excavator that has narrow tracks
But seriously, I might cut them shorter later.
I've seen pictures of 374 that has maybe over 1 meter wide pads
I don't know the exact lenght of the pad, but mine are 20mm long.
Old 10-29-2012, 01:06 PM
Everything is looking like it's coming together nicely. As far as the track width; It would depend on what the machine is going to be working on. Narrow tracks shorter frames for hard rock where no flotation is needed.
Old 10-29-2012, 01:13 PM
ihbuilder's Avatar
I Know the 385 ( which I'm building (2)) are 900mm (36")and 750mm (30") I'm making my shoes @ 64.25mm x about 19-20 mm .75" . I read somewhere that the 390 is just a renumbered 385 with a few added HP , etc
Old 11-10-2012, 08:31 AM
I started to make the cylinders
Old 11-10-2012, 08:56 AM
That looks very nice!
I would go for a little narrower track pads, other then that its a piece of art!
Old 11-10-2012, 09:25 AM
I've come to that conclusion too, I will make them slightly narrower
Old 11-10-2012, 11:32 AM
Yea, to bad you have to go thru all those pads again! Will be worth it though i think!
Old 11-10-2012, 11:48 AM
This machine is freakin awesome very very good skill you have I work on These machines and watching this build is great
Old 11-10-2012, 03:15 PM
kerst's Avatar
kerst kerst is offline
Looks beautiful!
Kerst
Old 11-10-2012, 09:16 PM
Beautiful job of the cyls Ari. Is that stainless steel for the pushrod?
Old 11-11-2012, 04:10 AM
Yep, it's 1.4305 grade stainless.
Old 11-17-2012, 05:30 AM
Got the rest of the cylinders done
