Old 01-25-2013, 10:07 PM
evo mike's Avatar
evo mike evo mike is offline
evo mike is on a distinguished road
Default Re: RC4WD 6X6 beast truck
Originally Posted by crazy4yachts View Post
Hey Mike what type of battery or batteries are you using and also what suspension up grades did you go with. I'm looking to do a lot of up grades to my mini Beast as I like to call it. I want to put bigger shocks on it but I'll need to also change the lenght of the 4 link set-up to use bigger tires.
John
Hi John,
Using a 3S lipo 11 V +/- 5500mAh
But as I showed I am using a Leopard LBH3660/8T Brushless -3600kV-
Between motor and the old version Tamiya 3speed gearbox from the Bruiser I have this semi automatic transmission from Traxxas, It's more of a clutch system. But it works perfect ! (TWO SPEED W/Reverse Auto Transmission TC3 Traxxas E-max)
As a ESC I am using a 150 A with a BEC of 6V 6A
Tyres are from RC4WD : Crazy Crawlers 2.2
You can still find them in different stores or on ebay
I did cut the foam a little bit and put weights in the rims.
Furthermore a used these shocks from RC4WD Spark Comp Shock with Ti Shaft (110mm)
They make the suspension a whole lot better !
The originals are to short and to stiff.
Then I changed the punisher shafts, I am using the ones from Gmade.
Finally I changed the XVD's from the front axle.
Broke one (!!??) after my first run, but furthermore these XVD's are stronger and they allow more steering.
Mike
