Go Back   RC Truck and Construction > RC Truck's General Discussion. > Get it out of your system! HERE!
Get it out of your system! HERE! You have a gripe,bone to pick, Tamiya vs Wedico or just have to let it out! THIS IS THE ONLY PLACE TO DO IT!
Old 01-30-2013, 03:43 PM
Acadieman Acadieman is offline
Acadieman is on a distinguished road
Default Re: Stupid mfu that keeps shutting down
Originally Posted by rc_farmer View Post
To get your blinkers to work properly, you may have to do a couple of things:
1. adjust the position of your knuckle-rod on your servo horn.....
the blinking function will work at a mininum EPA setting, i.e 80% and above....this may vary slightly with radio brand. Having said that, if your servo rod is farther out to the end, you may get over-throw before your blinking function will work, thus binding your servo.
2. once you get you mechanics set, you can then adjust yoiur End Points to the desired throw all the way to 150% or as far as your servo will travel w/o binding.
Ok, I'll give that a try.
I changed my radio's joystick configuration. Ratchet is now on the left stick, for left to right. That was a bigger job than I planned, and did not know how to go about it.
