Old 03-02-2013, 09:45 AM
Default Re: Driven front axle options?
This was asked of one of the axle brands, but not answered:
What about a 'throughput' front axle, like the forward unit on the dual-rear-axle semi's. Does no-one make a simple off-the-shelf unit yet, instead of us having to buy ones with metal casings at $150 and up?
I know Joe and Willy DIY'd them a while back, but isn't anyone even making a ~kit~ for those of us with minimal tools?
Only Robbe really makes one 'off-the-shelf', and I honestly don't like their axles when compared to Tamiya ones. Dislike 'em enough to ditch my 8x8 'Panther' chassis if I can do it with Tamiya parts (and they AIN'T cheap)
So, guys... is there a way for us Neanderthals?
Old 03-02-2013, 12:25 PM
It is not that hard. Buy a TLT axle Kit, extra pinion, and axle housings. Then just trim the two pinion halves to fit together. This has been done in a few threads here on the forum. All you will need for tooling is the normal tools to assemble an axle and a hobby knife for the mods to the axle housing.
Here is a pic of a set of TLT's used that way. He is using them as steerable rear axles but it is still exactly the same.
Old 03-02-2013, 01:29 PM
Travis: (or whomever has done this, like Willy & Joe)
What about the flanges on the axle casing? Do the casing halves that are being used have the flange/edge that overlaps (malke side?), or the other one? I ask as if it needs removal, it can be used as an alignment assist, right?
As for 'alignment', to assure that the 'throughput' pumpkin matches with the central piece, and the gear-mesh inside is ok, you just bore out the screw-holes (as you'll either have two bottoms with no access, or two tops with no thread to grab), and use long bolts and nuts instead, and it'll line up sufficiently well?
If no-one has done a good step-by-step, mebbe I should do one when I do it, for the archives and all that, hm? If there is one, this is a ~great~ place to put the link to it.
And lastly: how well do the TLT & Semi axles compare width-wise (assuming the same rims/tires all around) and gear-ratio-wise? I don't want a nasty issue with a semi rear end, mismatched to a TLT front (Can you put the gear-guts from one into the other and vice-versa to maintain ratio?)
Sorry for all the questions, but when I get onto sommat thats been bugging me for years, I tend to run with it.
WhiteWolf
Old 03-02-2013, 01:56 PM
Yes they are fanged and that is why I said you will need the hobby knife. Only one flange needs cut off the other will be for alignment.
You will be using two identical pieces molded with the same holes so alignment will be no issue.
It is a simple mod and you are only trimming one piece to make it so there is not much to show.
The TLT, tractor truck, high lift, cc01, and cr01 all use the same gears. With the same rims on a TLT and a semi axle the TLT will be a lot wider. You will have to be creative to get the offsets of the rims to work.
WhiteWolf
Old 03-02-2013, 02:03 PM
CustomRCmodels's Avatar
CustomRCmodels CustomRCmodels is offline
CustomRCmodels is on a distinguished road
WhiteWolf
No cutting required . You just use the male housing (no lip ) part from a straight input/output rear axle and replace that with the non-input/output housing on the TLT-1 axle . Plain simple bolt on .
(Wild)-Willy
CustomRCmodels
Old 03-02-2013, 02:07 PM
You right Willy I was just giving the option to do it from available parts from a place like tower hobbies who doesn't carry the semi axle housings. But you right if you have the other housing there is no mod needed just bolt it together.
Old 03-02-2013, 02:26 PM
If you get 2x TLT-1 axles and 2x center axles ( from a 3 axle truck ) , then you have all the parts for the swap without having to purchase the extra axle housing ( a-parts 0005467 + pinion-gear ) , since then you just use the left over housing half from one TLT-1 axle and fit that as last rear axle . In that case you also would have to do some cutting , but not that much , to fit it together .
(Wild)-Willy
CustomRCmodels
Old 03-02-2013, 02:13 PM
WhiteWolf
As for the rim-offset , lock at my Krupp ( at the bottom of this page )
You use the rear inner rims as front rims
http://www.customrcmodels.com/Tanks/id86.htm
(Wild)-Willy
CustomRCmodels
Willy:
My imagination, or is the front actually a little narrower than the outer rear axles? As I've got a semy with stock rear width, it'll help me tell if the deed
is not only do-able, but would look decent enough under the body...
Thanks for the assistance,
WhiteWolf
Old 03-02-2013, 02:37 PM
Willy:
WhiteWolf
The fronts line up with the outer rears . Its just an illusion from the angle how that photo was taken . For a better comparison here with a King Hauler body :
all-wheel-drive rig , but with bigger and wider tires .
Therefore the front tires stick out from the fenders ( and the rear is much wider as stock )
http://customrcmodels.com/Trucks/new_6wd_project.htm
with stock semi-rims and tires they would be just covered by the fenders
here is a good photo from Travis's Mack :
(Wild)-Willy
CustomRCmodels
Old 02-20-2016, 01:31 PM
SmallHaul's Avatar
Is there a driven front driven axle with remote locking diff and complete disconnect? Or are they all open and locked only?
I have setup some wedico metal axles that can do this and it is a nice feature.
Scott
"No load is too Small"
