Old 03-02-2013, 02:26 PM
CustomRCmodels's Avatar
Default Re: Driven front axle options?
Originally Posted by fhhhstix View Post
You right Willy I was just giving the option to do it from available parts from a place like tower hobbies who doesn't carry the semi axle housings. But you right if you have the other housing there is no mod needed just bolt it together.
Travis
If you get 2x TLT-1 axles and 2x center axles ( from a 3 axle truck ) , then you have all the parts for the swap without having to purchase the extra axle housing ( a-parts 0005467 + pinion-gear ) , since then you just use the left over housing half from one TLT-1 axle and fit that as last rear axle . In that case you also would have to do some cutting , but not that much , to fit it together .
(Wild)-Willy
CustomRCmodels
