mario the truck looks grate love the cab and the detail .
Thanks Big John. I love these lights. The company who sells them are great to deal with and my first order came with a 10 bucks off coupon and free shipping over 40 bucks on my next order
![]() Really good variety on colors, sizes, lengths .....etc. http://www.modeltrainsoftware.com/bl-214f.html Thanks Keith. I can't wait either ![]() I'm like a kid at Christmas waiting for the tree to be lit up for the first time after decorating...lol That's a great suggestion Whitewolf ![]() I need the shrink tube to seal and isolate the solder connection for the 2 main wires which will connect to the light relay. Glad you like Nathan, I'm very happy how it looks. I think the combination crazy glue and then silicone should hold them all in place very well.... And yes, I like clean looking wiring, not birds nest wiring ![]() ![]() These lights have a 5-12 volt working range. I plan on connecting them to the aux relay on the SS Tronix board which has a 5 volt output. Not battery voltage of 7.2 Why do you ask? Am I forgetting something? I'm going to connect all 20 LEDs in parallel to a relay that can handle 2 amps or 60 led. I should be ok right??? Hey Dwayne. No luck at the Source. The smallest they have is 1/4" tubing which is way too big for magnet wire. Good news is, I found some today at a local electrical shop! ![]() ![]() Thanks Dabomb6988 . I'm very anxious to not only see it lit up, I've enjoyed the build but it's time to finish! Thanks Rccrazy523, I like the unique cab that pro builder made for us and the spectacular paint job he did. Mario |
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. YOU WANTED THE BEST AND YOU GOT THE BEST THE HOTTEST BAND IN THE WORLD...KISS!!!! |
i agree with you mario..time for me to get cracking too and finish my builds also
So I've just run into a set back on the Black Passion build
![]() ![]() I got the cab skirt lights all done, tested and looking fine. I attached them to the cab mounting plate and then that's when trouble came up. When marked out the holes for the lights I used the same spacing as the sleeper lights to make it look right. Well, I just discovered I have one led on each side which is in the exact same position as the front mounting brackets for the steps! ![]() ![]() ![]() Plan B - I need to screw the step to the vertical edge of the mounting bracket and remove the horizontal edge will work. Sad part is I have about 4 inches of slack because of the light wires for the step lights which are glued on! ![]() ![]() It's been a rough day. I was ready to start dealing with the problem right away but thought.... I'm rushing this. I'm upset I won't get it done as quick as I wanted but hey, this build has never been rushed and had no big problems. Now I rush a little and look what I get! So , I'm on a shutdown for the day! Grabbed a Bud out of the fridge, kicked back on the couch and I think I'm gonna watch the nationwide Bristol race and start fresh tomorrow. Have to turn the brain off for a bit....lol. Thanks for listening ![]() Mario |
All right, I'm done with my freak out session. Couldn't help myself but get back at the build. I was all upset for nothing! Took about an hour to cut and modify the step bracket and the cab plate is now installed and fits perfect.
![]() Sorry bout the drama queen complaining ![]() ![]() Back to building........ Mario |
