http://www.dynamicsealing.com/gp_2-passage_unions.html I have thought about how to make the swivel as well (for a long term skidder project of my own). I think you might be able to use some fins to turn the swivel housing with a hydro line into each side of the housing where the lines enter at an angle to push the fins with the fluid. Of course you would need some gears in there to do the actual turning and you would have to limit the rotation so your hoses to the grapple wouldn't get twisted. To do a true 360 degree swivel you would need to have a hydro slip ring for the grapple hoses. Not sure how it could be done but one day maybe I'll give it a try. |
Forgot to add, the skidder looks great!
Man,This looks great! You called me the expert? If mine looks half this good,I'll be a happy Guy! Real nice job on the grapple!
Don't know how much room you have left,but the hydraulics will take up a bunch of it. Don't know if you have seen the mini pumps from stahl. It only took 15 months for me to get it. Guess ole-Ric babe is havin problems getting stuff from Germany. But it's very small & has a brushless motor(reversable) & you can set the rpm on it so your not making a bunch of heat running the pump wide open for nothing. Another draw back on the mini is the price!You can buy two regular pumps for the price of one mini. If you want I'll post some pics of the differance between the two pumps. Keep up the good work! FGD |
uncle freddy ,TTM has them in stock ![]() ![]() ![]() Ben , you did a fantastic job :thumbsup: . IHSteve
