Have a look at the HeyOk lighting controllers that RC4WD are now selling.
http://store.rc4wd.com/Brake-Reverse...er_p_3131.html This particular one has several outputs, you can have an always on for headlights, a switched output for driving lights that comes on with forward throttle, the tail lights are dim while driving and are always bright for brake lights with the throttle in the neutral position, and with reverse throttle the reverse lights come on. You could always just ditch the switched front output and you have always on headlights and tails, with switched brake and reverse. They've recently started selling their products and they have a few different options for lighting modules. |
For the stick movements: do you refer to the valve movements ? Br, Tom |
i like to have all of the engine rev anytime work is done so, if i have enough mixes available i mix everything to command the sound. i just overhauled this machine for someone and all i need to do is figure out which light system we are going with so that i can clean up the wiring. http://www.youtube.com/watch?v=4fX5O2wond4
Nathan |
Here is a vid of a full scale 996G, turn up your speakers and notice how much it throttles up just turning: https://www.youtube.com/watch?v=XtlYjiBTukw and this how i set up an RC 996G: https://www.youtube.com/watch?v=cmTSjSnnCAY Much more realistic than just having the drive run the sound IMHO.
Nathan, i just watched more front end loader videos and i see what you mean about going to idle when you change directions... so, you would only mix the sound to the drive? What if you run the lift or turn when you are not moving, would the engine speed up on a full scale machine?
