Old 07-29-2013, 08:17 AM
SmallHaul's Avatar
Default Re: Light system options?
Originally Posted by oztruck View Post
There is a small unit that also has sound that will do all of what you want + indicators and can be configured that when it is not moving the brake light stays on.
It is called a Turbo9
http://9rc.com/9turbo/index.php?main...&products_id=1
Cheers Chris
We are already using servonaut for sound but, that does look like an interesting option.
Originally Posted by Tp_hofmann View Post
I changed the original wedico electronic to servonaut.
S20 with rear and brake lights in conjunction with a ml4 do the job now :-)
Br,
Tom
We are using SMX and already have all of the control functions mixed to control the sound. So, with your setup do you still have the beeper sound when backing up and do you have all of your stick movements mixed to sound? That would be great to have the back up beeper.
Originally Posted by Sentinel View Post
Have a look at the HeyOk lighting controllers that RC4WD are now selling.
http://store.rc4wd.com/Brake-Reverse...er_p_3131.html
This particular one has several outputs, you can have an always on for headlights, a switched output for driving lights that comes on with forward throttle, the tail lights are dim while driving and are always bright for brake lights with the throttle in the neutral position, and with reverse throttle the reverse lights come on.
You could always just ditch the switched front output and you have always on headlights and tails, with switched brake and reverse.
They've recently started selling their products and they have a few different options for lighting modules.
That looks like a nice system and it seems to do everything we need.
Scott
"No load is too Small"
Old 07-30-2013, 04:09 PM
Tp_hofmann Tp_hofmann is offline
Tp_hofmann is on a distinguished road
I dont use sound in the cat.smx&s20 can be combined and the rear beeper will work.
For the stick movements: do you refer to the valve movements ?
Br,
Tom
Old 07-30-2013, 06:04 PM
SmallHaul's Avatar
Br,
Tom
Tom,
i like to have all of the engine rev anytime work is done so, if i have enough mixes available i mix everything to command the sound.
i just overhauled this machine for someone and all i need to do is figure out which light system we are going with so that i can clean up the wiring.
http://www.youtube.com/watch?v=4fX5O2wond4
Scott
Old 08-18-2013, 01:34 PM
Tom,
Scott, I don't think any operator, or 1:1 machine would be on the job very long, with direction changes taking place without idling the engine down first. It seems less realistic to me with the RPMs running up when cycling the hydraulics.
Old 08-18-2013, 08:32 PM
SmallHaul's Avatar
Nathan,
Here is a vid of a full scale 996G, turn up your speakers and notice how much it throttles up just turning:
https://www.youtube.com/watch?v=XtlYjiBTukw
and this how i set up an RC 996G:
https://www.youtube.com/watch?v=cmTSjSnnCAY
Much more realistic than just having the drive run the sound IMHO.
Scott
Old 08-18-2013, 09:10 PM
SmallHaul's Avatar
Nathan, i just watched more front end loader videos and i see what you mean about going to idle when you change directions... so, you would only mix the sound to the drive? What if you run the lift or turn when you are not moving, would the engine speed up on a full scale machine?
Scott
