Old 04-05-2015, 06:50 PM
Default a little dx9 help
so I want to switch between my trucks all 3 are on
1) I scroll to system set up
2) click yes
3) model select
4) now here is where the problem is....
my dump truck and quad king both shoot into reverse once the rf signal
is lost. the peterbilt don't move at all. I have the throttle cut set to 0%
on the C switch 0ff 0n 0ff. all the trucks are set up the same viper 15 esc
rc4wd 65 turn motors
the two trucks will do this with the throttle cut off set to on or off
I cant have fly away trucks at cabin fever
HELP!!!!!!!
Old 04-05-2015, 08:06 PM
Krewmember's Avatar
Default Re: a little dx9 help
2) click yes
3) model select
HELP!!!!!!!
Hmm, maybe you could try programing the fail-safe to set the throttle to zero?
Shawn
Old 04-05-2015, 08:29 PM
Shawn
I agree set your fail safes and rebind. Also did you center the left stick? You can do it your self the manual shows you hoe to do it.
Old 04-06-2015, 03:48 PM
recalibrated the sticks sliders and right knob. then rebound rx adjusted esc's
and still had the same thing happen. once I try to change trucks the dump truck
goes into full reverse once it loses rf signal..
same thing for the quad king
Old 04-06-2015, 06:57 PM
Save your self a headake and call Horizon Hobby they are very help full I have used them several times and if your radio has a problem they will take care of it. Ed
Old 04-08-2015, 11:11 PM
all 3 trucks ran fine on the dx6. all could be powered on in stand by and
selected and driven while the other two were parked..
all 3 are back on the dx6 and running as should be. the esc's were not touched after
swapping from the dx9 to the dx6 and no reverse issue now
Old 04-09-2015, 07:06 AM
mavrick0 mavrick0 is offline
You should always recalibrate your ESC's to the new radio and once all the calibrating is done for all trucks and all servos and everything then rebind the radio's to the RX's. With the spectrum radio's when you bind the radio to the rx is when it sets the failsafe. So when you first set things up and then change them then it will change where the failsafe will be and sounds as if the failsafe is throwing the ESC's into reverse.
Old 04-27-2015, 02:23 PM
pigeonfarmboy's Avatar
Info above is good. Make sure you understand, the position your sticks/switches are set when binding are setting the fail safe. If you're throwing reverse when binding, it's going to go to that position when rf is lost.
Throttle cut should not need to be used, if that's reversed, that's likely causing your issue.
Check your monitor section to make sure there's nothing strange going on.
