Old 05-20-2015, 06:19 AM
cosworth34677's Avatar
Default made a tank and smal problem?
i made a oil tank for my loader the other day fit fine and dosen't leak, but
there is this every showing lair of oil on the top of the tank around the fill
hole. and it kind of bothers me, why doe it do this? is there a fix? and what did i do wrong?
Old 05-20-2015, 08:36 AM
Serviceguyuk Serviceguyuk is offline
Location: Mostly a little world of my own but otherwise in the Bolton area in the North West of England
Serviceguyuk is on a distinguished road
Default Re: made a tank and smal problem?
It may be as simple as a little over filling.
Oil does heat up in any hydraulic system and will expand as your pump works.
Try draining or syphoning a little oil out and then run it.
Just trying help
Old 05-20-2015, 10:59 PM
thebigo thebigo is offline
Did you vent your tank? Install a small vent tube somewhere behind your tank.
Old 05-21-2015, 06:41 AM
Just trying help
i took out a Little oil. helped alot but still dose it.
how do you keep the oil from coming out the vent?
Old 05-21-2015, 05:49 PM
chris deacon's Avatar
Fit a long pipe on it and keep it higher than the tank?
Old 05-22-2015, 03:58 AM
i took out a Little oil. helped a lot but still dose it.
Chris is right, just run a pipe higher than the tank top. If you are worried about leakage you can get a filter/breather end fitting but always keep that upright and higher than the tank top. Gusto make small fittings and I'm sure they make a 3 or 4mm glass/ceramic breather end fitting that will simply push into the end of your overflow pipe.
Bets of luck
Just trying to help
Old 05-22-2015, 04:21 AM
I ran out time to edit my post but as an alternative you can use a small engine fuel tank filter like this one probably available from anywhere.
http://www.aliexpress.com/item/Small...234031721.html
Just trying to help
Old 05-22-2015, 06:02 AM
cool! well that leads me to another question where can i get a filter for the oil ? i need something inline or in tank.
Old 05-22-2015, 12:03 PM
Joe25's Avatar
Joe25 Joe25 is offline
Joe25 is on a distinguished road
Could you post a link?
Make peace or Die! 1st Bn 5th Marines
Old 05-22-2015, 02:27 PM
Airplane fuel filters will work, that's what Fumotec supplies with his hydraulic systems.
Old 05-22-2015, 02:59 PM
going by the hardware store on the way home from work, what about a weed eater fuel filter?
