Old 08-25-2015, 09:48 PM
plow jockey's Avatar
Default Scania 8x8 dump
Finally bit the bullet and got this Scania 8x8 all metal dump. Really impressed with this truck right out of the box. In the middle of moving so I don't have a lot of time to play with this yet. Here are a few pics.
Old 08-25-2015, 10:03 PM
chris1210's Avatar
chris1210 chris1210 is offline
chris1210 is on a distinguished road
Default Re: Scania 8x8 dump
Congratulations on your new rig, this truck has a lot of lesu parts in it. I'm sure you will enjoy it :-)
Old 08-25-2015, 10:12 PM
Thanks. I'm impressed so far.
Old 08-26-2015, 06:15 AM
chris1210's Avatar
You should make a video of it moving and especially on the hydraulic
Old 08-26-2015, 08:58 PM
I will someday.
Old 08-30-2015, 01:33 PM
Digger_Bear Digger_Bear is offline
Digger_Bear is on a distinguished road
My friend got one of these, but fluid oil tank leaks so waiting for replacement. Had a little drive of it and it's nice truck.
Old 08-30-2015, 05:53 PM
Haven't tried mine out yet. Still in the process of moving. Hopefully my hydraulic tank don't leak. Thanks for the heads up.
Old 08-31-2015, 07:19 AM
We measured 150ml of oil and added to tank, but found the tipper even without load would gradually start lower by itself. So added about 20-30ml but tank was full so spilled out, so maybe the overfilled system caused the tank to leak by over pressure or maybe was the cause of the tipper not holding in up right position to start with. Will know more when replacement tank arrives.
Old 09-01-2015, 08:17 PM
MoRockN's Avatar
MoRockN MoRockN is offline
Nice Truck!! Tank will leak no matter what, gives it kind of a scale oil/dirt realistic look so i don't bother with it anymore.
Old 09-03-2015, 09:50 AM
MACK Daddy's Avatar
Looking good
Good to see your still around with your rc's
Alfy
Always Wheeling, Always Dealing !
Old 09-03-2015, 08:49 PM
Thanks. Keep me posted.
Thanks. Figured there would be some type of hydraulic residue some where.
Originally Posted by MACK Daddy View Post
Looking good
Alfy
Thanks Alfy. Trying to find more time to finish my old builds and start new ones.
Old 09-08-2015, 08:59 AM
Rimrock Rimrock is offline
Those black CNC milled axles from Lesu are the most durable one can get for 1:Tamiya according to my opinion. I have opened quite a lot different type axles. In my region those are the standard for construction trucks when it come to replace original Tamiya axles. In general, stay away from the yellow/light blue ones sold at rc4wd, among others, which are quite bellow in quality, but not so different in price, from the Lesu ones.
Old 09-08-2015, 09:14 AM
Nice truck. Should be hard to get that one stuck.:-)
Sealing the lesu tanks that have caps on each end that leak.
Drain the oil out.
loosen the set screws that hold the end caps on and remove end caps.
Clean the inside of the tank and both end caps well with rubbing alcohol.
Using clear silicone caulking place a bead of it all around each end cap over the rubber O-ring and push the end cap back on.
If you put enough silicone on it you will have silicone that oozed out the edges of the tank that can be wiped off using rubbing alcohol. Remove the excess silicone right away and it will all come off nicely. Let the tank sit over night. It won't leak again.
Old 09-08-2015, 01:52 PM
Drain the oil out.
Great thanks for sharing. I've decided I now want one of these so asked my friend to source one to me here in the UK.
Old 09-08-2015, 04:10 PM
When one see in general what junk have come out of Asia regarding RC machinery the last years, this 8x8 truck seams surprisingly well built, with many high quality parts. I am actually surprised, positively. Hopefully they will continue on this path, and we will see more trucks that are much more value for money than the Scalearts
Old 09-08-2015, 08:19 PM
chris1210's Avatar
one thing you guy didn't notice about this truck is its dual steering need an adjustment, I still can't find a good solution for that. Anyway I'm very happy with it.
Old 09-08-2015, 10:35 PM
It goes with the saying. You get what you pay for. These are top notch for sure.
Thanks. Be fun trying.
Drain the oil out.
Havent checked to see if it leaks yet. [still moving] That's the first thing I will do if it does thanks for the tip.
I'm very impressed and pleased with mine.
There should be adjustments on the drag link or tie rods.
Old 09-09-2015, 05:11 AM
Yes we spotted that issue on me friends one of the steering wheels is wrong and catches on the suspension during full lock. We presumed it was a one off faulty.
Because the other 3 wheels are correct no way of adjusting it. On the one I saw it looked like the arm between the wheel axle (sorry don't know technical name) was a fraction too short giving to much tow out on that one wheel. The arm looked non adjustable, well I didn't want to risk breaking it as it wasn't mine. Anyway seeing my friend and truck again in a weeks time so going to replace it with a Tamiya arm or a custom made one as I've some bits spare. Plus he's replacement tank has arrived this so will let you know if it cures the issue.
Old 09-10-2015, 10:11 AM
Quick update my friend fitted new tank and that leaks as well. He's since got the first tank welded up so hopefully that has fixed the problem.
Old 09-11-2015, 05:59 AM
chris1210's Avatar
After your friend replaced a new tank where is the leak located? You can test it by removing the breather and seal it with a 3mm screw then run the pump to see where the leak comes from. I guess the leak comes from the pump and not the tank.
