Go Back   RC Truck and Construction > RC Truck's Defenders of the land. > Tanks!
Tanks! If is has Tracks it goes here..
Old 04-27-2011, 09:15 AM
Brel's Avatar
Brel Brel is offline
Default Tamiya M26 Pershing
Here are some shots of my Tamiya pershing as you can see from the close ups of the tracks this tank get used outside in the dirt for a more natural weathered look
Old 04-27-2011, 09:32 AM
Car5858's Avatar
Car5858 Car5858 is offline
Default Re: Tamiya M26 Pershing
I see that you have the IR battle unit in it.
Old 04-27-2011, 01:55 PM
Brel's Avatar
yes it is IR battle ready, all of my Tamiya tanks and the Heng long tiger 1 are battle ready
I go to meets when I can and it is great fun trying to recreate WWII battles in 1/16th scale
I am giving the tank its annual pre season service at the moment and have ordered some replacement road wheels because the plastic housing the bearings has split on a few of them, I have checkd the final drives and they are clean and free of debris and not worn at all
Old 04-27-2011, 02:37 PM
You might want to check your bearings in the roadwheels for plastic compatible grease! Had a lot of guys buying cheap bearings from China that had the wrong type of grease in them which caused bunches of problems until they replaced the bearings or completely degreased the bearings and put in plastic compatible grease. Pershing is a great tank to battle with.
LYNN
Old 04-27-2011, 04:18 PM
Brel's Avatar
here is a picture showing one of the cracked wheels along side a good one
when I get the new wheels I am going to fill the gap around the bearing housing with epoxy resin to make them stronger, why did tamiya make them this way when they would have been better making them as one solid disc without the gap in them
Old 04-27-2011, 05:45 PM
Car5858's Avatar
That was the engineers trying to save on materials cost
If you can find a bras tube the correct size, cut small rings to fit over them.
The other option would be to cast new wheels from aluminite.
Old 06-01-2011, 07:42 AM
Brel's Avatar
I have filled in the gap with epoxy resin and replaced the bearing with new ones that have been greased with plastic compatable grease
it is back together in one piece and here are a couple of shots of it by on the river bank in my local park
Old 06-01-2011, 08:29 AM
Car5858's Avatar
Nice work Brel, happy your up a running again.
Old 06-01-2011, 09:12 AM
Panther F's Avatar
Looks great! The Pershing is a fun build.
Makes me want to get another Pershing but this time build a WWII version. (someday )
- Jeff
Old 12-09-2012, 05:06 PM
RCscaler's Avatar
RCscaler RCscaler is offline
RCscaler is on a distinguished road
I don't know much about RC tanks but this looks awesome. It would be cool if it could shoot bbs.
Old 12-10-2012, 12:37 AM
rcman rcman is offline
the heng long version shoots plastic airsoft pellets!
Old 04-02-2013, 05:23 PM
Brel's Avatar
I had a heng long version once, but sold it to get the Tamiya Pershing
I have a HL Tiger that I have converted to IR so that I can battle Tamiya IR fitted tanks
