Old 09-24-2011, 09:51 PM
Default Day cab dump truck
I am building another day cab cab over dump truck but this one will just be a tandem drive and the shortest cab I could make. When I am done with this one it will be for sale.
Specs
1: Converted Globe Liner
2: 3 speed trans with Integy 4:1
3: Tazer 12T ESC and a 55 turn motor (stock motor is used only for mock up)
4: 2 1600Mah batteries in parallel for good run time
5: Hitec 645MG servos for steering and shift
6: Custom front rims with Tamiya SS, stock rear rims and tires with RC4WD hubs
7: Bushings through out only bearings are in the 4:1 NO bearings used in the rest of the truck. They are just not needed in our trucks + if a bushing gets worn you still get to play but if a bearing fails you are done to you replace it and most just buy the cheap $20-$30 bearing kits which are a wast of money anyway.
8: RCE220 RC Small Dual Relay Switch to control the screw drive motor
9: Carson 50:1 gear motor to operate the screw drive
10: My own custom screw drive
11: Styrene bed
12: color will be ?????
Well here are the pics of what I have so far.
Thanks for looking.
