Old 12-11-2011, 09:37 PM
Diesel Demond's Avatar
Default Diesel Demond's work ride
My western star with a load of flat bar stock just weighing over 44,000. Eaton fuller 10 speed with a Mercedes benz engine! Power is good but it seems like the truck could use more gears the way the rpm's sound! It also needs a bath in this picture!
This is a load I delivered to Northern Minnesota that makes the openings for hopper bottoms. I don't know which manufacture of hopper bottoms.
Old 12-26-2011, 02:44 PM
Default Re: Diesel Demond's work ride
Well those mercedes engines are junk! Truck is in shop with bad head gaskets! I knew this truck ran at to high of a rpm at 70 mph! The sister to this truck has had same problem twice and the dealer even said these engines were junk. alot of problems ! so my hunch was right about running to high of rpm! Looks like its gonna get fixed and i will be back in it! So long new MACK vision dream!!
Old 12-26-2011, 05:14 PM
If your boss buy's you a Mack, Make sure it has the roadranger tranny and not that triple countershaft POS! Trust me on this one! 17 year's of frustration. Mine will get swapped out soon.
Old 12-29-2011, 09:04 AM
Not sure why you would call the triple counter shaft junk, Dad bought a Mack new in 1979, 300, 5 speed, it could have used some lower gears but that truck was tough as nails. It was dragging a dump trailer all of it's life, the late Mack 7 speed would have been great in that truck.
Old 12-29-2011, 04:13 PM
Hey Nathan, Shift quality in a Road Ranger is alot faster, which make's a big difference, when upshifting on hill's. I've had the 12speed and the older T2180 18speed, after demo'ing a new International a few year's ago, My Mind is made up, Road Ranger!
The triple countershaft arrangement is high enertia-I.E. it act's like a flywheel and doesn't want to spin down fast for shifting. I'm in a 12 wheel Dump.
There are road's in my neck of the wood's, that I have to split every gear, or the engine fall's flat on it's face, but K-dub's pulling double bellie's with 9speed's shifted just fine-Yes I became friend's with them, and let them pass me on the hill. I can't jake my shift's, due to computer programming! 1997 vintage.
The other problem is Dealer rebuild's cost more and idependent shop's hate working on them. Case in point My 1988 RD with 2 lift axles went in for tranny work, I was told to not ever bring it back to them again. It was a nightmare to work on.
Yes I'm biased from the "School of hard Knock's"
Tough as nail's doesn't count when it won't shift, that when abuse happen's.
I've had Mack's for 17+ year's, not my favorite truck! But thank's to the new emissioned engine's that can't stay out of the shop, I'll just keep my beast!
Old 01-07-2012, 11:23 AM
I understand what your saying on jake shifting with my truck it needs a computer adjustment cause that jake kicks on so fast and drops the rpms right now its annoying especially when your trying to speed shift to get a look at that honey and when i hit the splitter sometimes it goes in gear then i have to pull it back out cause it just revs like its in nutural and then i look like a dumb ***! I drive a KW also thats in are fleet with a CAT 3406 and eaton 13 speed and i can take my foot all the way off accellerater before i put it in gear with the jake on and still catch it! older truck less emissions and way easy to shift with jake! plus it sounds way better baaaaaaaaaaahhhhhhhhhhhhhhh!!!!!! my jake impression lol!
Old 01-07-2012, 03:11 PM
Just add 8" chimney's to your impression! LOL!
Old 01-07-2012, 05:09 PM
That's the way you want it to work! especially trying to get out of the basement in really soft ground.
If you don't have a Jake, shifting @11-1200 works very well too in low range.
I've never heard the term triple countershaft, is that a reference to Fuller transmissions?
Old 01-07-2012, 05:57 PM
Joe the old 5 speed mack I had had 3 counter shafts in it , whereas the eaton/fuller has 2 . The eaton/fuller is a charm to shift compaired to the mack . I started on that mack 5 speed and it's not that bad ,you get use to it . That old mack had a million on it before she went down and dad desided to scrap it .
Cory , your brap is too long and too soft
Old 01-07-2012, 08:53 PM
Hey joe, this link show's the difference beween single, twin, and triple countershaft
http://www.zafr.com/trucktcom/transmissions.htm#mux
Hope this help's!
Old 01-20-2012, 10:41 AM
Hey Cory, think I saw you at 694 and silver lake road this morning about 8:00 sitting in traffic. I tried to hollar at you on the radio, but every one was chatting and I couldn't hear anything
Old 01-22-2012, 08:20 PM
yep that was me i turned radio off because of all the chatter couldnt hear myself thinking of how long it was gonna be before i get back to the shop with that snow! what were you driving?
