Old 11-24-2013, 07:32 PM
cosworth34677's Avatar
Default so i got leaks! EVERYWHERE!!!!
ok i been working on converting my old screw drive dump trailer to hydraulic! well got everything working smooth strong and nice. then this morning when i took it ti the park for the first real day out, well......... it dripped, then leaked then just flowed antifreeze out like its a river. what happened?
ok this is the setup.
1. mangon hrc pump
2. smc pneumatic cylinders
3. tamiya kit esc.
its pouring out the little push lock fittings. it was working for a week and
it was going really good. but then this!
you know i broke the man rule though i was showing it to a pretty hot single mom and her son! thats what did it!!
by the way please help!! what should i do? new fittings new cylinders? burn it all with fire?
Old 12-18-2013, 04:32 AM
kenobi kenobi is offline
kenobi is on a distinguished road
Default Re: so i got leaks! EVERYWHERE!!!!
Hello, I have owned the Magom HRC pump myself and the instructions i got from Magom in spain was that it should never be used with normal hydraulic fluid , you should use radiator coolant , also called antifreeze. it is thinner than normal hydraulic fluid and has less pressure in the hoses and cylinderes when operating.
I had the system on my wheeled loader and it also leaked like crazy with normal hydraulic fluid.
Old 06-27-2014, 05:41 PM
Crash Crash is offline
Crash is on a distinguished road
I have the same problem and I am using antifreeze. I can't get a tight enough fit on the connections. I haven't been able to run my new loader yet because the hoses leak like crazy. I am almost ready to get the crazy glue out.
Old 06-27-2014, 06:17 PM
i ended up gett a new set of cylinders and better fittings. they are a tad bit larger. and using retainers from robart helped so much! hope that helps?
Old 07-10-2014, 12:21 AM
ricm ricm is offline
how did you go with the hot mom?
Old 07-10-2014, 06:25 AM
lol she was like " ok....... not impressed" at lease that was the face she gave. i did go to lunch with her a few times
Old 07-10-2014, 07:34 PM
good recovery - I'd say you almost had a win
