Old 12-27-2014, 06:05 PM
justin justin is offline
justin is on a distinguished road
Default Dx8 channel mixing help
Hi all
Wondering if some one could help me by explaining how to channel mix my spektrum dx8 radio Only want the pump to go on wen I move the joysticks
Justin
Old 12-27-2014, 10:54 PM
Default Re: Dx8 channel mixing help
If we're talking about an excavator here, Master is the valve channel, Slave is the pump. Throttle = boom, aileron = bucket, eleveron = stick, gear or 3 = pump. I assume you'll be using Aux1 & Aux2 for tracks.Then there's getting the +100 & -100 values in the right order, depending on how you wired the esc to the pump. Mix 1 throttle/pump, Mix 2 aileron/pump, Mix 3 eleveron/pump
Old 12-28-2014, 02:48 AM
Sorry It's a wedico 966 loader
Old 12-28-2014, 02:04 PM
Whatever, everything above still applies, except throttle will be for/rev motion & it'll be rudder for steering, so rudder/gear or aux? (I'd put it on gear myself). You'll need to put a speed control on your pump, can't work without it. And if you do use gear switch, the values for throw are -100 on one side of switch & +100 on other side. Once you figure out which side of gear switch makes pump pressure (pump turning correct rotation), the side of the switch that should be off needs EPA set to 0 so pump turns off.
Old 12-28-2014, 03:49 PM
Ok thanks ile try it today
Old 12-28-2014, 03:52 PM
Does the radio need to be set on plane or heli mode
Old 12-29-2014, 02:08 AM
apfubar apfubar is offline
It is probably easier for it to be setup as a plane...
The swash plate setup on the heli may make things harder.
Old 12-29-2014, 02:58 AM
Ok thanku Andrew. It's doin my head in lol
Old 12-31-2014, 07:52 PM
Here is how I have my 966 setup:
- channel input config: pump channel - inh (removes it from any switch)
- Programmable mixes:
1. On > pump channel, rate: 100/100, offset 0, switch on (this sets zero to -100)
2. Source/input channel > pump channel, rate: -100/100, offset 0, trim inh, Switch on
(For each hydraulic valve you repeat point 2)...
I suspect the -100/100 though is the key.
Cheers,
Ap
Old 12-31-2014, 08:40 PM
Cheers,
Ap
Thanku Andrew Ile try this over the wkend
Thanks again
Justin
