Old 11-01-2012, 11:19 PM
Default twins
was going to wait a bit before I started this till I got further along , so mostly parts I'll put long run parts on the mill while I'm turning parts on the lathe . with no tool changer on the mill , it's hard to concentrate on turning while changing tools and parts out on the mill . I hope to change that someday soon
210 pads in a days work still need 2 ops done yet
21 pads /plate
the carbody frames
I got the front idlers and sprokets cut but still have yet to take pics
Old 11-02-2012, 12:09 AM
rockNmayhem's Avatar
Default Re: twins
Steve you have been very busy lately. Progress looks great on those pads. Now when do I get a set to throw on my CAT?
Keep it up.
Tyler
~Tyler~
RockSolidCustoms
Old 11-02-2012, 02:30 PM
RCLogger's Avatar
RCLogger RCLogger is offline
Default Re: twins
Looks like another great build taking place Steve. I am looking forward to watching your progress..
Greg
Old 02-02-2013, 06:17 PM
Default Re: twins
little progress . back on aluminum in the mill for awhile so no steel cuttin for the TD40 right now .
thanks or looking
Old 02-02-2013, 06:28 PM
Default Re: twins
Very nice! Two at a time is a good idea. You won't need a quick change because you can just switch machines!
Old 02-02-2013, 06:45 PM
Default Re: twins
lol actually 1 wont have a stick which is the 1st to get finished it's needed in the sheet metal department
Old 02-02-2013, 08:51 PM
Default Re: twins
Dang, that looks nice! And beefy! I like it.
What is the little piece of equipment, sitting in the background, with the rims piled on it's base? A snow cone maker? The handle makes me think mini drill press, but I don't see a motor, chuck, or cord anywhere. I thought maybe a hand tapper, but there is no handle for turning the taps. Can't be an arbor press. Not even leverage with those little handles. I give up!
Old 02-03-2013, 04:14 AM
Default Re: twins
if you really want to know http://www.alspi.com/corepress.htm I found it in a scrounging trip at a place similar to HGR industrial surplus . I thought it was a press of some sort . So, I grabbed for some wild idea of using as 1 till I investigated it a little more . It's got a granite base and a dial indicator put in it and we got a hight test stand
Old 02-03-2013, 04:39 PM
RCLogger's Avatar
Default Re: twins
Nice work Steve. Its a good thing Reg doesn't live close to you, you two working together could have an assembly line happening..
cheers
greg
Old 02-03-2013, 04:47 PM
Default Re: twins
cheers
greg
Haha! I wish! That would be sweet!
Old 02-03-2013, 05:18 PM
Default Re: twins
Thanks Greg , yea your right I could use a good tig welder who has time to weld right now
finished up a little aluminum turning early , pulled the alm chips out and threw in some ss . the result was 2 drive spindles gotta cut my keyways and drill the 4 screw holes for the ring gear. yea I'm using my trusty ol hpi savage axle parts I couldn't find good small bevel gears without breaking the piggy bank . I'll be keying all my shafts on these to eliminate any possible slippage . Designing the track frames and drive housing . going to try to mill them out of solid bar .
Ahh ,another full week of cussin in the shop
Old 02-03-2013, 05:43 PM
RCLogger's Avatar
Default Re: twins
You must have a ton of chips in your shop... Metal flying, someone could start a business just melting down chips for you..
Old 02-03-2013, 06:11 PM
Default Re: twins
yea I just filled a 55gal drum full of alum in a month
Old 02-03-2013, 11:03 PM
Default Re: twins
Huh? Are you thinking about getting into shin grafting or something? A tissue coring press? One of those, 'I didn't know that even existed' kind of things. Using it as a height test stand, in the mean time, while you read the manual, doesn't sound to bad.
Track sprockets and gears look great, by the way!
Old 02-17-2013, 04:51 PM
Default Re: twins
did some practicing on 3D modeling I'll be making it in 2 pieces doo to what I have on hand in material .
roughed in
after the .078" ball mill broke
thanks fer lookin
Old 02-17-2013, 05:40 PM
Default Re: twins
Me likey!
Old 02-17-2013, 05:42 PM
Default Re: twins
Did you see these gears Steve?
They would be better than the old straight cut bevel gears.
Old 02-17-2013, 06:16 PM
Default Re: twins
I wonder how hard they are ? these nitro ring and pinions are pretty tough .
Old 02-17-2013, 07:31 PM
Default Re: twins
Ahh, that counterweight is perfect!
Old 02-17-2013, 10:24 PM
Default Re: twins
That looks great!! Keep it up!
