Old 08-17-2010, 11:51 PM
Default Re: Driven front axle options?
Scott the Axial trans also gives you a 3:1 reduction as well so no need for a GRU on the motor.
Old 08-19-2010, 02:16 AM
SonoranWraith's Avatar
It's a dry 115 degrees.
The gear doctor and bamatech (both german) sell modified semi axles as steer drive axles but they are pricey. Can even get locking but they are hard on spiders.
Old 08-19-2010, 07:47 AM
SmallHaul's Avatar
Thanks for all the info.
Which rcchannel axle is used for the front of a rig? Would it be narrower than a tlt-1 axle?
Scott
"No load is too Small"
Old 08-19-2010, 07:29 PM
FreddyGearDrive's Avatar
FreddyGearDrive FreddyGearDrive is offline
Admin RIP FGD 2-12-59/12-19-11
FreddyGearDrive is a jewel in the roughFreddyGearDrive is a jewel in the roughFreddyGearDrive is a jewel in the roughFreddyGearDrive is a jewel in the rough
SmallHaul, This is the diff between stock & rc channels narrowed.
Now carson & rc channel.
With these two you can run super singles w/out dickin around.
Now TLT.
F-350.
This will give you the low down in a row.
Hope this helps.
FGD
Old 08-19-2010, 09:43 PM
SmallHaul's Avatar
Great info Freddy! You should make this a sticky.
So, starting from narrowest to widest:
1) Stock front axle
2) Carson
3) Rcchannel narrow
4) TLT-1
5) F-350
Does that look right?
If so, where would I get a Carson axle? and how much?
Scott
Old 08-19-2010, 10:31 PM
BINGO!That's the exact order.
SmallHaul,the carson front diff is like $200.
For the same price you can get this.
But! Now you have to buy a set of semi rear diffs to match the front. The rear diff that comes w/the front is two wide for semi. But you can't beat the look of these babies.
The carson is like 2mm narrower than rc/channel.
The carson I was purchasing from pmd. But surf a little & you can pick them up a lot cheaper.
Hope this helps!
FGD
Old 01-02-2011, 03:24 PM
Snochaser's Avatar
Hope this helps!
FGD
So are these Carson axles?
Old 01-02-2011, 01:10 PM
CustomRCmodels's Avatar
CustomRCmodels CustomRCmodels is offline
CustomRCmodels is on a distinguished road
Now TLT.
F-350.
Hope this helps.
FGD
since I just came across this thread again and it’s a sticky one ,
I figured I add this here :
Example of the use of a TLT-1 axle in one of my 6WD projects:
http://customrcmodels.com/Trucks/new_6wd_project.htm
(Wild)-Willy
CustomRCmodels
