Big Boys of the road 4x4/6x6/8x8/10x10 Trucks This forum is for those multiple axle trucks and other vehicles on and off road. |
ooo very nice! whole new fleet eh?
If you are looking for cheap tamiya based driven steer axle conversion kits then watch my store ![]()
Thanks Nick To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
Thanks, Nick. Yes, a slight extension to the fleet, Your front axles will be needed for two of the Benz.
Here is a sneak preview for you ![]() ![]() ![]() ![]()
Thanks Nick To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by NRS91; 07-01-2020 at 10:04 AM. Reason: Resize Pics |
Thank You, Nick. I have a good feeling about your project. I will Have your product Incorporated in my fleet. The original Tamiya axles are right, and if they get tuned tight when built, they will last a long time. I have axles with far more than three hundred hours on them, still running smooth. So let's have the two current Mercedes on the bench run your front axles.
I am looking forward to working with you. Nick. |
The Mesh is extremely important on casted gears; There is no shortcut at that.
However, Tamiya does not make metal parts in the house. Therefore the gearbox has two different pressure angles on the gears, Old standard and new. Witch makes the gear to go down faster than it would with the same pressure angles. Now Japan is a monoculture, so the boss does not know that, and a new gearbox or axles will not be on the horizon for some time. But the work so I stick with them. |
Currently Active Users Viewing This Thread: 7 (0 members and 7 guests) | |
