Go Back   RC Truck and Construction > R/C Truck's Manufacturers/Venders/Retailers > S n P Customs
S n P Customs Custom builds, Custom parts, Custom metal polishing...
Old 01-10-2012, 01:44 AM
Dreamweaver's Avatar
Weaver Of Dreams
Default Re: Custom fenders
Send me a pair!!! I can make mounts for them to..
Mike "DREAMWEAVER" Johnson
Old 01-23-2012, 08:56 PM
Bigg Redd Bigg Redd is offline
Bigg Redd is on a distinguished road
Can these be made for a Wedico Pete!!!!!
Old 01-29-2012, 09:39 PM
Stylin n profilin's Avatar
Stylin n profilin Stylin n profilin is offline
I'm tryin Boss!
Stylin n profilin has a spectacular aura aboutStylin n profilin has a spectacular aura aboutStylin n profilin has a spectacular aura about
Ok here they are....there $55 shiping included....Must make your own mounts..everyone mounts them different to there own taste..unless someone wants to make mounting kits...hint...hint..hint.....anyone....
One Bus Stop Short Of The Short Bus...
Old 01-30-2012, 02:15 AM
Weaver Of Dreams
Originally Posted by Stylin n profilin View Post
Ok
I can't really make a "kit" cause they can be mounted at different heights.. But I can make them to order...
Old 02-05-2012, 12:06 AM
1985 kenworth's Avatar
Question Re: Custom fenders
how would you make them to order by which tamiya or wedico tractor you have and which suspension you are using on the tractor
Old 02-05-2012, 12:11 AM
They would be made for a Tamiya truck with a standard suspension or a custom suspension as long as the ((wheel base) typo should be wheel spacing of the rear axles) stays the same. The fenders are made to fit a standard Tamiya truck.
Old 02-05-2012, 10:40 PM
ok i have a kinghauler and a globeliner the suspension is stock but the wheelbases on them are longer than the standard box stock trucks are you sure the wheelbase would be an issue i thought the axle spread would be the a problem ..i am talking about someone building the mounts to mount them on the trucks
Old 02-06-2012, 01:57 AM
Weaver Of Dreams
I build them so that they fit the way you want them regardless of the make of truck or type of suspension. I get measurements from you, I let you determine how high you want them to sit from the wheels and the ground then build them to fit.
I guess I could make a "Stock" set. If you have a stock Tamiya suspension, stock ride height ect and you want the full length fender as they come from John then no measurements are needed. I could also build a set that has a little extra adjustment to them and someone with basic soldering skills can make them the height they want and just trim the excess.
Old 10-27-2012, 08:59 PM
RacerX43 RacerX43 is offline
RacerX43 is on a distinguished road
I'm in for a set of the Fenders. Do you accept Paypal ? If so, what is the Address. Did you make or buy the rear Bumper ? Does it light up ? If so, I want one of those too please. Please let me know about the Paypal and the Bumper please. Hope to Here from you soon.
Thank you very Much,
Robby
