Go Back   RC Truck and Construction > R/C Truck's Manufacturers/Venders/Retailers > S n P Customs
S n P Customs Custom builds, Custom parts, Custom metal polishing...
Old 01-29-2012, 09:39 PM
Stylin n profilin's Avatar
Stylin n profilin Stylin n profilin is offline
I'm tryin Boss!
Stylin n profilin has a spectacular aura aboutStylin n profilin has a spectacular aura aboutStylin n profilin has a spectacular aura about
Default Re: Custom fenders
Ok here they are....there $55 shiping included....Must make your own mounts..everyone mounts them different to there own taste..unless someone wants to make mounting kits...hint...hint..hint.....anyone....
One Bus Stop Short Of The Short Bus...
Old 01-30-2012, 02:15 AM
Dreamweaver's Avatar
Weaver Of Dreams
Originally Posted by Stylin n profilin View Post
Ok
I can't really make a "kit" cause they can be mounted at different heights.. But I can make them to order...
Mike "DREAMWEAVER" Johnson
Old 02-05-2012, 12:06 AM
1985 kenworth's Avatar
Question Re: Custom fenders
how would you make them to order by which tamiya or wedico tractor you have and which suspension you are using on the tractor
Old 02-05-2012, 12:11 AM
They would be made for a Tamiya truck with a standard suspension or a custom suspension as long as the ((wheel base) typo should be wheel spacing of the rear axles) stays the same. The fenders are made to fit a standard Tamiya truck.
Travis
Old 02-05-2012, 10:40 PM
ok i have a kinghauler and a globeliner the suspension is stock but the wheelbases on them are longer than the standard box stock trucks are you sure the wheelbase would be an issue i thought the axle spread would be the a problem ..i am talking about someone building the mounts to mount them on the trucks
Old 02-06-2012, 02:01 AM
Weaver Of Dreams
Wheel base would not be an issue unless you changed the drive wheel spacing, which you can't do if using a stock suspension. However if you were to use the air ride kit that Russ sells then you could change that spread. However if you were to change the drive spread then the fenders would not fit anyway.
Old 02-06-2012, 01:57 AM
Weaver Of Dreams
I build them so that they fit the way you want them regardless of the make of truck or type of suspension. I get measurements from you, I let you determine how high you want them to sit from the wheels and the ground then build them to fit.
I guess I could make a "Stock" set. If you have a stock Tamiya suspension, stock ride height ect and you want the full length fender as they come from John then no measurements are needed. I could also build a set that has a little extra adjustment to them and someone with basic soldering skills can make them the height they want and just trim the excess.
Old 10-27-2012, 08:59 PM
RacerX43 RacerX43 is offline
RacerX43 is on a distinguished road
I'm in for a set of the Fenders. Do you accept Paypal ? If so, what is the Address. Did you make or buy the rear Bumper ? Does it light up ? If so, I want one of those too please. Please let me know about the Paypal and the Bumper please. Hope to Here from you soon.
Thank you very Much,
Robby
