Old 02-06-2012, 06:29 PM
grumpygrady grumpygrady is offline
grumpygrady is on a distinguished road
Default Re: Hyd Pump - What did I just buy?
it says they are good for 300psi ?
Old 02-06-2012, 07:11 PM
ihbuilder's Avatar
thats all well and good , but what happens when you get oil in the magnets . I've tried this with 2 of the smaller 1's I got as complete units .
Old 02-06-2012, 08:15 PM
ok i am confused
the one that was on ebay was a mag drive pump
it does not matter if you get oil on the magnets as they don't touch anything
in fact there is plastic between the two magnets
or are you talking about the one that was converted to shaft drive?
Old 02-06-2012, 08:18 PM
the 120 series puts out 120 kpa which is 17 psi
http://www.csgnetwork.com/presskpapsicvt.html
Old 02-06-2012, 08:24 PM
ihbuilder's Avatar
the reason for the mag coupling is to eliminate shaft seals I have 2 complete pump and motor set up with a mag drive . I tried 1 , as soon as I got oil in it it lost conection . They are not designed to pump oil with out removing the mag drive . then lies the ? if the poly pump gears will hold up in oil I might abandon this altogether do to what the pump was designed for ,deffinately not oil .
Old 02-06-2012, 09:05 PM
gun's Avatar
gun gun is offline
HillBilly Home Boyeee. WAZZZUP!
gun is on a distinguished road
steve get back in your cage and find my bricks and keep one finger on the green button
SHANE... Member of the Central Plains Mini Truckers..
Old 02-06-2012, 09:49 PM
ihbuilder's Avatar
do what Paul make sure you put some mice in that rack for this guy
Old 02-07-2012, 12:20 PM
thanks for the reply and for answering my questions
it is nice to be able to ask questions and have a adult conversation with someone without be called out or being made fun of because of an miss-understood question or reply
unlike at scale4x4 where folks jump down anyone's throat that asks a question that may or may not have been answered in the last ten years.
it seems that i need to ask the company why they say the pump will pump oil or heavy fluids, as you have tried and failed
again thanks for your time and trouble answering my questions
grumpygrady
